Author Topic: RC drift Srbija  (Read 34699 times)
Offline T-rex
Re: RC drift Srbija
« Reply #15 on: October 19, 2011, 12:10:36 AM »
How hard your tires? Like really hard plastic or like plastic with rubber? I have Tamiya TT-01D, stock drift tires good for speed drift but not for slow, I bought HPI T-DRIFT for slow drift. http://www.r2hobbies.com/eng/proddetail.php?prod=rcvp3320010
« Last Edit: October 19, 2011, 12:13:25 AM by T-rex »
Offline Punto Abarth
Re: RC drift Srbija
« Reply #16 on: October 19, 2011, 12:20:33 AM »
not really plastic, more in a direction of rubber, but harder rubber, with really slick surface and hard foam inserts.
Soft set is way softer, feels much gripier under the fingers.
koliko god da ga istreses, zadnja kap mora pasti u gace
Offline Bigneda
Re: RC drift Srbija
« Reply #17 on: October 19, 2011, 12:58:34 AM »
evo sad gledam onu zadnju sliku i vidi se neka oznaka na gornjoj strani ramena, II moze biti da ispod pise I i to bi bilo po tvojoj teoriji 2 pozicije verovatno sa 1 i 2 stepena minusa ili nesto slicno...
Tu vertikalnu prvi put  vidim kao i ceo princip prednjeg trapa posebno sponu sa prednje strane kao onu za upravljanje, za svrhu nemam pojma ali mislim da ga malo preterase sa komplikovanjem.  mmmm
Offline T-rex
Re: RC drift Srbija
« Reply #18 on: October 19, 2011, 01:26:52 AM »
Looks like mine from the kit, try T-Drift tires, or make them from ABS pipe, you will see really big difference. And why you want to make minus?
Also you can put electrical tape on tires
Re: RC drift Srbija
« Reply #19 on: October 19, 2011, 05:25:26 AM »
@ bigneda:
ta spona sa predje strane nije za upravljanje, nego je dijagonalna veza sa inboard amortizerom/oprugom.
Upravljacka spona je klasicno postavljena, iza osovine, sa donje strane glavcine.
Vertikalna spona izmedju ramena mislim da sluzi za podesavanje neceg bas zajebanog :) ali cega, to jos nisam provalio.
@ T-rex: trying to make - cambers in front because of:
a) trying out different handlings
b) trying to put low offset wheel tucked under wheelarches :)
Offline Bigneda
Re: RC drift Srbija
« Reply #20 on: October 19, 2011, 11:44:28 AM »
...ma vidi se sta je za upravljanje nego nije se videlo celo vesanje pa je cudno izgledala ta sa prednje strane. A sistem amortizera se nije video pa reko cemu sad to :)
Re: RC drift Srbija
« Reply #21 on: October 21, 2011, 06:35:20 PM »
provalio sam namestanje camber-a :) s unutrasnje strane se imbusom drzi kontra, a spolja se uvrce/izvrce kraj spone  :sljus
uzeo sam danas iskrinu dremelicu, pa mozda uskoro bude nekih prepravki na bmw-u
Offline Bigneda
Re: RC drift Srbija
« Reply #22 on: October 21, 2011, 07:49:44 PM »
NE diraj nista, de ces bre na BMW sa brusilicom !?  (:sok:)
Re: RC drift Srbija
« Reply #23 on: October 21, 2011, 09:42:55 PM »
chopshop  ;D
originalno sve ostaje, ocu da napravim nesto novo, nesto divlje. Ali otom potom.
Offline rogy30
  • Ansmann Vapor, Reely Titan, Blue Tanga 69
    • tv-berza
Koji motor za drift ?
« Reply #24 on: January 28, 2013, 09:48:31 AM »
Poozzz drustvo!
Treba da kupim motor za drift i jedan od ova tri ponudjena bi trebao uzeti..ALI.. neznam koji pa vas molim za pomoc i misljenje!
Pogon je za 4WD
PRVI
Elektro motor klase drift 80T
Obr/min: 5.300
Snaga: 80W
Struja: 11A
Napon: 7,2-7,4V
Tezina: 164g
Razmera: 1:10
Dimenzije: 70x35x35
DRUGI
Elektro motor klase drift 21T
Obr/min: 20.000
Snaga: 135W
Struja: 19A
Napon: 7,2-7,4V
Tezina: 164g
Razmera: 1:10
Dimenzije: 70x35x35
TRECI
Elektro motor klase drift 19T
Obr/min: 22.500
Snaga: 140W
Struja: 19A
Napon: 7,2-7,4V
Tezina: 164g
Razmera: 1:10
Dimenzije: 70x35x35
Kako se na bosanskom kaže DNK? Da nije komšijino?
http://tvberza.com
Offline rogy30
    • tv-berza
Re: Koji motor za drift ?
« Reply #25 on: February 01, 2013, 01:11:29 AM »
Posto niko nije znao da iznese svoje misljenje, ako ima jos ljdi koje zanima drift, uzeo sam
DRUGI
Obr/min: 20.000
Snaga: 135W
Struja: 19A
Napon: 7,2-7,4V
Tezina: 164g
Razmera: 1:10
Dimenzije: 70x35x35
Pokazao se idealan za drift  makar meni :mhm
http://tvberza.com
Offline rogy30
    • tv-berza
Re: RC drift Srbija
« Reply #26 on: February 08, 2013, 11:30:38 AM »
Pozzzz
Evo javljam se  :big smile
Doduse jos sam pocetnik, sredjujem jos auto, balansiram i podesavam.
I naravno vezbam   oo))
Kada gledas tako je lako  :hehe
I jedno pitanje kada srte spominjali zakljucavanje diferencijala...nije mi jasno kako, ako neko ima sliku ili bolji opis  mmmm
Ja sam iz Novog Sada, pa ako ima neko neka se javi.
http://tvberza.com
Offline Bigneda
Re: RC drift Srbija
« Reply #27 on: February 09, 2013, 02:00:07 AM »
Ako imas diff sa trkacima i planetarcima mozes slobodno unutra umesto masti ili silikonskog ulja nagurati papira :) da obican papir ili neki iz starih novina radi odlicno posao a posle se sve lako vrati na fabriku...
Ako imas sa kuglicama onda super lepak ili jako stezanje da ne mogu preskociti ;)
Offline rogy30
    • tv-berza
Re: RC drift Srbija
« Reply #28 on: February 12, 2013, 12:34:28 AM »
Hvala na savetu!
Jos nisam zakljucavao dif, cim napravim javljam kako se ponasa auto.
Evo da predstavim moje malo cudo pre i sada...ali ima jos posla...za drift nadam se da ima jos neko iz Novog Sada  ()-()
http://tvberza.com
Offline Agama
Re: RC drift Srbija
« Reply #29 on: February 12, 2013, 10:19:34 AM »
Opasna mašina !
www.rcbuggyland.com
