(ne samo) RC fly HUMOR
Started by tibeteagle, January 09, 2009, 05:44:18 PM
rajker
rajker
rajker
LazarStan
-2Pac
http://www.dreamerbeats.com/
The Rules for pilots:
Every takeoff is optional. Every landing is mandatory.
If you push the stick forward, the houses get bigger. If you pull the stick back, they get smaller. That is, unless you keep pulling the stick all the way back, then they get bigger again.
Flying isn't dangerous. Crashing is what's dangerous.
It's always better to be down here, wishing you were up there, than up there, wishing you were down here.
The ONLY time you have too much fuel is when you're on fire.
The propeller is just a big fan in front of the plane used to keep the pilot cool. When it stops, you can actually watch the pilot start sweating.
When in doubt, hold on to your altitude. Tests prove that collision with the sky is not harmful.
In a 'good' landing you can walk away. In a great landing, you can say the same of the plane.
Learn from the mistakes of others. You won't live long enough to make all of them yourself.
You know you've landed with the wheels up if it takes full power to taxi to the ramp.
The probability of survival is inversely proportional to the angle of arrival. Large angle of arrival, small probability of survival and vice versa.
Never let an aircraft take you somewhere your brain didn't get to five minutes earlier.
Stay out of clouds. The silver lining everyone keeps talking about might be another airplane going in the opposite direction. Reliable sources also report that mountain goats have been known to hide out in clouds.
Always try to keep the number of landings you make equal to the number of take offs you've made.
There are three simple rules for making a smooth landing. Unfortunately, no one knows what they are.
You start with a bag full of luck and an empty bag of experience. The trick is to fill the bag of experience before you empty the bag of luck.
Helicopters can't fly; they're just so ugly the earth repels them.
If all you can see out of the window is ground that's going round and round and all you can hear is commotion coming from the passenger compartment, things are not at all as they should be.
In the ongoing battle between objects made of aluminium going hundreds of miles per hour and the ground going zero miles per hour, the ground has yet to lose.
Good judgment comes from experience. Experience comes from bad judgment.
It's always a good idea to keep the pointy end going forward as much as possible.
Keep looking around. There's always something you've missed.
Remember, gravity is not just a good idea. It's the law. And it's not subject to debate.
The three most useless things to a pilot are the altitude above you, the runway behind you, and a tenth of a second ago.
LazarStan
,,Always try to keep the number of landings you make equal to the number of take offs you've made."
Hahaha smejao sam se kao lud na sve,ovo sam izdvojio  lol
-2Pac
rajker
Quote from: rajker on November 27, 2014, 09:02:35 PM
mmmm mmmm mmmm kako sad to ???  mmmm mmmm mmmm
https://www.youtube.com/watch?list=UUeK6fHS_XaXc2mN2f82j1DA&v=13C_gs4a3Tw
(:good) (:good) (:good)
Svi sadržaji na ovom YT kanalu Aleksa Greva su veoma korisni za modelare, RC pilote svega i svačega što leti na daljinsko. Odlično objašnjava i sagledava situacije rizika, na šta treba praktično obraćati pažnju, kako da se reše ili izbegavaju rizici i još mnogo toga korisnog. Ne, ovo nije za humor, ali je istina da ima puno smešnih navedenih situacija. Preporuka za svakoga.  (thumb)
rajker
rajker
 mmmm a sta ako duva vetar ?
rajker
 :big smile :big smile :big smile FAA
Treba reći Deda Mrazu da smo stigli u 21. vek i vreme je za promenu njegovog prevoznog sredstva na nešto brže.  :big smile
rajker
