KODOVI ZA HK (jeftiniji delovi)
Started by todor, May 13, 2011, 01:00:30 PM
djbojan
#60
jako dobri motori za multirotore, uz flashovane simonk ESC-ove imate extra letelicu
NTM Prop Drive Series 28-30A 750kv / 140w     ()-()
$14.11
http://www.hobbyking.com/buddy.asp?code=26D5E3F2-95EF-441E-AE66-3968C6409767
ZIPPY Flightmax 4000mAh 4S1P 40C
$32.31
http://www.hobbyking.com/buddy.asp?code=D9F9C385-7CA2-4BD1-BBDA-8F53D3859A5F
Gatti.Gatozza
sman
nedbojsa
pnedic
Danas sam napravio jednu porudzbenicu na HK. Ukoliko neko zeli da kupi nesto od dole pomenutih stvari, moze da dobije popust uz kodove koje ce dobiti od mene. Ko je zainteresovan, neka se mi posalje PP. Za svaku stavku imam po jedan kod koji traje narednih 14 dana (tj. do 02.04.2013).
U pitanju su sledece stavke:
1. http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=14543 - popust $0.09
2. http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=28384 - popust $6.75
3. USB AVR Programming device (http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=21321) - popust $0.80
miša2002
pnedic
#67
Izvinjavam se sto sam prethodnu poruku postovao na pogresno mesto umesto ovde !
Evo kodova:
1. http://www.hobbyking.com/buddy.asp?code=BDD24C63-CD50-45A7-9C63-5BAAFF023E84 (Male XT60 to Female T adapter)
2. http://www.hobbyking.com/buddy.asp?code=F46843EA-9F10-43DC-ADE1-E931330DE4EC (Trainstar Tough trainer 1.4m PNF)
3. http://www.hobbyking.com/buddy.asp?code=B011995D-4FB1-49EA-ACA5-46C287C61BBC (USB AVR Programming device fro AMTEL processor)
Kodovi validni do 02.04.2013.
pnedic
nedbojsa
