HK Shippment
Started by pnedic, March 13, 2013, 10:06:13 AM
matic
baterije mi salju preko     Express Mail Service to SERBIA (Lipo) 500g - 999g US$28.66
A stanicu  International (Registered) Air Mail 1.5kg US$23.59 Pitao sam ih zasto nemam link za traking, rekli su mi ako sam dobro razumeo da ce biti naknadno postavljen link jer se ceka na stanicu od 3 do 5 dana. Opet kazem ako sam dobro razumeo, a za baterije nisam pitao
Milosh
#227
Pre skoro mesec dana 18.11. HK mi je poslao paketic sa cudnom tracking oznakom LX000000XXFJ.
Preko 17track neta sam je ulovio i umalo se nisam slogirao
Date    Time   Location Service Area   Details
Nov 29, 2013   11:30PM    Yugoslavia - Belgrade     Parcel items received at delivery exchange
Nov 29, 2013   11:30PM    Yugoslavia - Belgrade     Parcel items in transit at next postal exchange
Nov 24, 2013   1:36PM    Fiji - Nadi     Dispatches created
posiljka je isla preko Fiji-ja!
Ajde lepo je da je barem stigla u Yugoslaviju  lol, ali mi je cudno to da je nas domaci track and trace ne vidi? Jel ima neko neki predlog sta da radim ili dokle da cekam da se ne pojavi?
miša2002
Pošiljka LX xxxxxxxxx FJ mi je uručena juče, a na pošti i dalje nema ništa ?
HK mi je poslao broj još 09.11.
Nigde nisam uspeo da vidim "tracking" !
Pitao sam, u međuvremenu, HK suport o tome. Odgovorili su da to zavisi od naše pošte i da je vreme od 6 do 39 radnih dana !!!???
Čemu služi ono "registered" ako ga nigde nema?
We are sorry for the inconvenience that may caused you. Regarding your concern, we checked that your orders xxxxxxxxxxxx and yyyyyyyyyyyyyy was still under its transit time. Your courier was Post International Registered Mail with 6-39 days transit time. We kindly ask for your patience regarding within this issue.
In case you will not receive your order within the allotted time. We kindly advised you to contact first your local post office and customs to check your parcel using your tracking number. It might have been there waiting for you to claim.
S obzirom da je odskora ovakav broj u upotrebi, i da imaš trag o prispeću, ja bih se raspitao u tvojoj pošti, ako ništa drugo, ono bar da znaš koji je postupak ili već.
Miša
#FFCC00
OK hvala na informaciji. Ja sam dobio broj 15.11. sto znavi da bi posiljka trebala da mi bude isporucena u narednih 7 dana.
disljenko
Jedno pitanje, poslata mi je posiljka sa HK-a 4.12 i stoji mi ovakav broj za pracenje 0005xxx, procitao sam u nekom predhodnom postu da bi trebalo ovaj broj da azuriraju u neki drugi kroz 2-3 dana medjutim kod mene ce sutra 7 dana i jos stoji taj isti. Dali je ovo uobicajno ili da kontaktiram njihov korisnicki centar?
miša2002
Dokle god ti stoji taj broj, pošiljka još nije poslata. Kad je "pošalju" dobićeš broj sa LXxxxxxxxxxFJ...
Ja sam 02.12. dobio taj fantomski broj, a 09.12. i broj za praćenje, samo ne znam gde i kako?
Pročitaj prethodna tri posta i biće ti sve jasno.
Sve mi se čini da su ove pošiljke ko preporučeno pismo i nigde se ne pojavljuje (usput) ... Slične pošiljke sam dobijao i preko SG pošte, ali su mogle da se prate, doduše sa desetak dana zakašnjenja i broj im je bio RFxxxxxxxxxSG...
Znači, naoružaj se strpljenjem i pomiri se sa mnmum mesec dana !..
Miša
#FFCC00
matic
Imam ja jedno pitanje. Narucio sam stanicu sa hk poslali su je 4. 12. Ali nemam traking na hk danas sam proverio na sajtu poste i postoji trakong broj. Ovo mi je ispisalo 09.12.2013 14:26:00CN - 100614 cn 100614 stoji pod rublikom mesto zna neko sta znaci ovaj broj.
miša2002
Ako bi mogao malo bolje da definišeš pitanje!? Gde ti je ispisalo to što navodiš?..
Takav traking broj ne postoji !
Svi imaju 13 cifara tj kombinaciju dva slova na početku i kraju, a između 9 brojeva.
Naravno, postoje i druge kombinacije, ali su one za nešto drugo !
Miša
#FFCC00
nedbojsa
CN 100614 - ti je prijemna pošta, tj. paket je primila china post.
azoran
Kao sto sam obecao evo malog update informacija vezano za sve one cije posiljke idu preko poste u Fiji-u i pocijnu sa sa puno nula.Posiljka je posle 17 dana od dana dobijanja broja za pracenje stigla na carini.Pretpostavljam da ce im trebati jos jedno 4-5 dana dok ne izvrse iporuku.Inace je posiljka sadrzala lipo baterije. (pijemo)
Evo od danas mi se posiljka iz Fiji-ja vidi i na nasem Track&Trace  :)aplauz.
Miki Va
Quote from: miša2002 on December 11, 2013, 03:29:22 AM
http://www.postfiji.com.fj/pages.cfm/services/track-trace/
miša2002
Quote from: Miki Va on December 13, 2013, 01:13:21 AM
Pogrešno si shvatio, broja nema nigde ni na jednom tracking sajtu ili kako već da nazovem to...
Pa prvo sam kod njih i gledao...
U svakpm slučaju ti hvala, ali broja i dalje nema nigde !!!
Jednu takvu sam već dobio, pre neki dan, ali i dalje nema nigde traga o njoj, iako im piše da osvežavaju bazu svaka dva sata !!!
QuoteThe Track & Trace records on this website are updated every two hours. Please note that currently only records after 11th of July, 2011 are displayed. Should you experience any difficulties please do not hesitate to contact us.
Miša
#FFCC00
disljenko
Kazete da treba da posalju taj drugi broj za pracenje, meni je posiljka kao poslata 4.12 ali mi jos stoji onaj broj sa nulama ovog oblika: 0005xxx, ali mi i evo posle 10 dana nije promenjen ovaj broj. Da li oni to salju na mail ili umesto ovog se pojavi taj drugi?
