Zanimljivi klipovi ( YouTube, ... )
Started by SABURO, March 07, 2008, 01:17:34 AM
ak
Gabor
Neverovatno... Spusti model na leđa, a posle prilikom leta se odlomi nos. Pogledajte snimak, vredi!  Za 3D  (res)
http://www.youtube.com/watch?v=bSyYW9Bl0ZM
Mythbuster
#1099
Quote from: bmxstefan@gmail.com on July 22, 2010, 02:37:59 PM
http://www.youtube.com/watch?v=-s62aarnTIw&NR=1  :pop:
Ako ti je ovo zanimljiv klip, u kome gledas snimak pogibije dvoje ljudi, treba da se zapitas da li je sve u redu s tobom?
Bolesno.
PS.
Slucajno sam ziveo u Australiji u to vreme i ova prica je bila sok za celu naciju.
Date:   01-MAY-1994
Time:
Type:   de Havilland DH.82A
Operator:
Registration:   VH-UNA
C/n / msn:
Fatalities:   Fatalities: 2 / Occupants: 2
Airplane damage:   Written off (damaged beyond repair)
Phase:
Nature:   Demo/Airshow/Display
Departure airport:
Destination airport:
Narrative:
Because of the extra drag caused by the wing-walking frame bolted onto the wings, the pilot had developed a take-off technique that would give him a decent climb rate despite the added drag. Unfortunately, this involved climbing at a speed very close to the stalling speed of the aircraft.
According to the investigation report, the engine failed soon after take-off because of a problem with the carburetor needle. The problem had already been identified on similar airplanes in other countries, but had not resulted in an Airworthiness Directive in Australia. The pilot tried to perform a flat turn to get back to the runway by kicking the rudder. This resulted in a stall and spin which killed both occupants.
Sources:
ATSB Occurrence Nr. 199401106
Izvestaj komisije:
http://www.atsb.gov.au/publications/investigation_reports/1994/AAIR/pdf/ASOR199401106.PDF
"Kakva bi tišina nastala kad bi ljudi govorili samo ono što znaju..."
Karel Čapek (1890-1938), otac naučne fantastike
"Ko uvece legne sa dupetom koje svrbi, probudi se ujutro sa prstom koji smrdi"
Srđan Dinči
bmxstefan@gmail.com
Ok stvarno se izvinjavam ako sam prekrsio neko pravilo foruma nekoga povredio ili uvredio!!!Ucinilo mi se da je clip sokantan pa sam hteo da ga podelim i sa vama!!!Nisam se izsmejavao tome niti ista slicno!!!Ako sam prekrsio pravilo foruma ili pogresno postavio post,u tom slucaju bih zamolio admina da skine to sve...Ocigledno je da sam na pogresnom mestu postavio clip,ma da se mesto gde sam postavio i zove zanimljivi clipovi sa youtube a ne lepi, sokantni ili smesni!!!A sto se tice pogiblja dvoje ljudi nije nimalo smesno!!!U vazduhoplovstvu se gine posto je to takav hobby,sport ili nekome posao i ne znam da li je to sramota kriti ili sta vec!!!Aaa sto se tice clipa ja ne znam da li je bolestan taj sto je snimao ili televizija koja je objavila to ili taj sto je postavio na youtube ili 620,284 ljudi koji su pogledali to!!!Mozda je taj clip i poucan u nekome smislu da se nebi ponovila ponovo takva surova greska...
ivanmagd
Mrzi me da trazim , ali je klip vec postavljen negde u ovom topiku, i nakon njega se cak podigla i rasprava sta se dogodilo i ko je kriv....
zgrujic
Quote from: ivanmagd on July 23, 2010, 12:00:05 AM
Nisam siguran za ovaj klip, ali na ovom topiku već imamo nekoliko padova pravih aviona i zmajeva i niko do sada nije dizao larmu oko toga. Nije lepo za videti, ali opet to je sve deo života, kako na nebu tako i na zemlji. Svaka avionska nesreća se detaljno ispituje kako bi se iz nje nešto naučilo i kako se ista stvar ne bi ponovila. Ako danas naučimo nešto iz njihovih grešaka sutra ćemo biti u boljoj poziciji nego što su oni bili.
Pogledajte 24. sekund...
http://www.youtube.com/watch?v=pkpWCu1k0ZI
kole
Topik se zove ZANIMLJIVI KLIPOVI, a ne ono sto je u njemu. Ime mu nije Smesni Dogadjaji, pa da se smejemo nekome ili necemu. Zanimljivo znaci, da ce biti vredno pogledati, privuci interesovanje i paznju. Da je sadrzaj poucan, da sadrzi neke poruke ili informacije.
Quote from: Mythbuster on July 22, 2010, 05:06:00 PM
Bolesno.
Sam kazes da je klip zanimljiv a ne pogibija. Nije ni mesto ni vreme da ti nekog osudjujes a nisi brate ni pozvan da dajes takva misljenja.
Kole
Aeroplan Jocika, vidi!
zgrujic
Mythbuster
Quote from: kole on July 23, 2010, 12:17:43 PM
Bolesno.
Kole
U pravu ste, gresan sam,izvinjavamo se, mnogo se izvinjavamo,  mozda je moj prag tolerancije na krvave scene nizi nego vas. Samo napred, ima jos takvih scena na Youtube, jos kad bih video neki smisao i vezu sa modelarstvom, bilo bi mi lakse.
A i :pop: se sasvim lepo uklapa u taj komentar.
Srđan Dinči
bmxstefan@gmail.com
Ako je tako ondaK da se sve to zaboravi!!!Jedna big . da se stavi na to!!!Idemo dalje!!! 23,july,2010 prvi let show time 4D,naravno ne ovo sa ovoga clipa ali uskoro ce biti i tako,motor je isti kao i na ovome osmax120ax...  ;namig http://www.youtube.com/watch?v=DLWgTki2yKQ&feature=player_embedded
Mythbuster
Srđan Dinči
saxpg
Evo sta se radi kad se model zakaci na drvo ( koga mrzi da gleda sve nek premota na 4:00 min )
http://www.youtube.com/watch?v=vpvsg3cngXk
