Zanimljivi klipovi ( YouTube, ... )
Started by SABURO, March 07, 2008, 01:17:34 AM
Ja sam juce imao problema,. Danas sve radi notmalno.
nedbojsa
Nije YT ali da ne otcvaram novu temu!
Zanimljiva slčica, koliko je verodostojna nisam siguran!
Tekst koji prati sliku:
"June 4, 1965 Mr. Privalov Valentin military pilot on this aircraft overflew a central span of the bridge over the river Ob. The day was hot sunny mostulyudi on the beach on the shore filled with vacationers, among whom were officers of the district headquarters, and suddenly the roar of the aircraft and the silver arrow rushes in front of everyone under the bridge, then suddenly soaring upward, lifting the huge wave of the Gypsies. The distance between the supports of the bridge 120 m, height 30 m span aircraft went into this "window" at the speed of 700 km / h At that speed, even a slight touch of the control knob changes the pitch of the aircraft by the meter. Airplane flying just feet above the water surface. The circumstances were complicated by the fact that only at a distance of 950 meters from the Municipal bridge downstream of the railway bridge ZapSib major highway and it took part. The pilot was only 5 seconds to catch soar up without hitting the bridge. Privalov threatened the tribunal, but the then Minister of Defense Marshal Malinovsky decided to keep the pilot in the ranks. Privalov, then served in Kubinka."
englez
QuoteZanimljiva slčica, koliko je verodostojna nisam siguran!
Mislim da nije prava slika.
Sa ovolikom brzinom je nemoguće podići od mosta na nekoliko metara pod ovoliki veliki ugao od oko 30 stepeni sa brzinom od 700km/h, osim ako nije izronio iz vode.
Izduvni mlaz bi gurao vodu iznad linije mlaza, a ne ispod, kako je na slici. Ovako izgleda kao da ispušta vodu pozadi.
Da bi se stvorili niži talasi na vodi, a ima ih nekoliko, potrebno je više vremena da protekne od pobude.
Ima još puno detalja koji ne štimaju ,ali prvi navedeni je sasvim dovoljan.
saxpg
A i ovoliko vode ne bi digao ni da se vertikalno zabio u vodu...
Anakin
matic
Ima domet od 30 do 120 kilometara zavisno od načina vožnje uz ukupno 12 kW snage. Možete ga voziti pedalama, a možete da prebacite i na motorno upravljanje.
Najveća brzina je ograničena na 65 km/h. Zanimljiva je takođe i integracija s pametnim telefonima.
http://youtu.be/TuXXZOGz5Ek
matic
nedbojsa
todor
Quote from: matic on October 16, 2013, 05:52:42 PM
Mnogo dobra stvar, ali koliko sam pogledao na netu cena mu je od 6000E  (:sok:)
Drugu polovinu snimka vezanu za letenje ,pogledajte pazljivije  :sljus  :_D :_D :_D
http://www.youtube.com/watch?v=CVFEDccid_A
nedbojsa
rajker
Gatti.Gatozza
