HK Shippment
Started by pnedic, March 13, 2013, 10:06:13 AM
nedbojsa
Meni takođe danas dva paketa promenila status da napuštaju HK 27. Aprila.
azoran
#61
Evo razloga zasto svima kasne posiljke iz HK.
Hong Kong Port Strike Continues
JOC Staff | Apr 25, 2013 4:46PM EDT
print
Li Ka-shing a Chinese billionaire with investments in container port facilities around the world, including in Hong Kong, has moved to end a four-week strike affecting operations at Hongkong International Terminals in Hong Kong by hiring new workers to handle ships and demanding protesters leave his building in the city’s Central District, Bloomberg Businessweek reports.
Some dockworkers, who are seeking better pay and working conditions, remained camped around Li’s Cheung Kong Center building, even after Li gave them a deadline to leave. About 300 workers also slowly walked on the road in front of the container port, blocking the road for several hours, leaving trucks backed up for “several kilometers,” according to Fox News.
The new workers and the return of some strikers to work have cut the waiting time for ships to an average of 20 to 25 hours, compared with about 60 hours when the strike started, Hongkong International Terminals said in an emailed statement to a Businessweek reporter. The docks are currently operating at about 90 percent capacity, but at least 100 vessels have already skipped Hong Kong since the strike started on March 28 in favor of nearby ports.
Work to rule by members of the HIT union ended on April 22 after an agreement was made with HIT management to give overtime compensation of 1.4 times the hourly rate, a victory for the union, according to the International Transport Workers’ Federation. Furthermore, an application for an interim injunction to stop demonstrators from picketing outside the headquarters of Hutchison Port Holdings, which owns HIT, was rejected on April 25.
JLZ
Ovo su lucki radnici u strajku.
Ovi nasi su avionski :D
BTW i meni jedan paket kao treba krenuti...
n.artur
Postojili razlika u brzini isporuke robe ako se recimo biraju stvari iz Nemackog skladista?
Losi 8IGHT 4.0 + Alpha RyanLutz + Spektrum Servo
Losi 8IGHT 4.0 Elektro + Savox Servo
Losi 8IGHT-T 2.0 RR + P5XL-T + Savox + Spektrum
Spektrum DX4R
zbabic
Porucio tri posiljke sa HobbyKing- a pocetkom juna (7.- 15. jun), Prva krenula iz Kine 15.06., druga 18.06., a treca 20.06. Prve i trece nema ni na vidiku, a druga stigla 03.07. Kad proveravam na trackingu, vidim da su u transportu, na sajtu nase poste, nema podataka o posiljci.
Do sad porucivao oko 30- tak posiljko, uvek stizale za 15- 20 dana od momenta placanja na HK.
Da li i vi imate slicna iskustva ili je do mene?
IVAN3D
I ja cekam paketic koji je krenuo 12.06. i nema ga nigde...
A prethodni paketic sa postarinom od 2.9$ mi je stigao za 4 dana iz Kine i posle dzedzio jos jedno 6-8 dana na carini....
Ne bi se iznenadio da dobijem poruku od HK da im se paket vratio.....
tihi
dva paketica od 12.6 isto ni traga ni glasa a neka sita dosla za 10 dana sve u isto vreme poruceno vec sam poceo da se brinem sto kaze ivan da  se nisu vratili .poz Marko
gizmo
Meni poslat paket 04.06. i jos uvek ga nema na nasem trackingu :(
Ovo pise na HK sajtu, izgleda da i nasi paketici idu preko Moskve  (___)
QuoteOrder delay in Russia
Entrant May 31 • Announcements
Dear customers,
Due to serious backlogs in Moscow airports, air mail services (including Speedpost) from Hong Kong to Russia are subject to severe delay. The respective published delivery standards for delay will not be applicable until further notice.
milomirts
da li bi neko mogao da mi da neki program za pracenje posiljki iz kine posto sam narucio jos pre mesec dana
a od posiljke ni traga ni glasa.
zbabic
#70
Jel skoro, nekom stigao paket iz HobbyKing- a, a da nije sadrzao baterije? Koliko je putovao?
http://www.trackitonline.ru
http://www.17track.net/index_en.shtml
zajko
 mmmm Meni stigla 2 velika paketa sa motorima, ESC, Li-Po baterijama za 3 dana... oo)) ali..... iz HK Nemacke   (pijanoo)
disljenko
Da li je neko imao slicno iskustvo. Porucio sam jedan paket 13.06. a poslat je 19.06 preko HK poste ali evo posle vise od mesec dana od kako je krenuo za srbiju jos nije stigao kod nas. Znaci preko onog broja za pracenje na njihovom sajtu pise da je 19.06 napustio KH i krenuo za Srbiju. Sta da radim?
Danas sam kontaktirao ove iz hobby-ja i kazu da pogledam u lokolnoj posti ili sa carinimo ali mi je to cudno jer po onom broju za pracenje nije stigao u Srbiju. Bar tako kaze sajt poste za pracenje.
nedbojsa
Dešava se to sa vremena na vreme, strpi se minu je jednom prilikom Air parcel poštiljka tako "visila u vazduhu" gotovo 60 dana. Oni poslali i napustila Hong Kong a u Srbiji se pojavila 60 dana nakon što je napustila Hong Kong.
azoran
Meni je stigla posiljka iz iz Singapura za 5 dana od kada se pojavila na trackingu,ali u njoj nije bilo nikakvih baterija.Dok je posiljka  iz Hong Konga putovala 10 dana.I naravno dva dana zadrzavanja na nasoj carini.
